DS3231 RTC reset pin
2019-10-23 4:27 AM
We are using STM32F769 NI with DS3231 MZ+ rtc , the rtc is not holding time after a power reset .
The reset pin in the DS3231 circuit is floating , althouigh reset pin has an internal pull up of 50k , can i leave the reset pin floating or should i connect a pull up ?
RTC
STM32F7 Series
2019-10-23 4:44 AM
Work together on this, it's not an ST part
https://community.st.com/s/question/0D50X0000BVpH0DSQV/stm32f7-interface-to-ds3231mz
Couldn't you just add one to the circuit an check that off as an issue?
More likely you don't have the battery wired properly or there is some other issue with the circuit, chip or design
