Doubt in Keil uVision
gerardo
Posted on December 11, 2014 at 10:18
Hello guys,
I´m developing an application in Keil uVision and I am getting this message.
What does this parameters mean?
Program Size Code = ¿Flash?
RO-Data = ¿?
RW-Data = ¿?
ZI-Data = ¿?
3 REPLIES 3
Posted on December 11, 2014 at 15:00
If in doubt RTFM
Code - Executable Instructions
RO-Data - Read Only, Constant data/arrays
RW-Data - Read Write, Variables in RAM with values
ZI-Data - Zero Initialize, Variables in RAM which are zero/cleared
The FLASH foot print is the combination/sum of Code+RO+RW, the RW data is there because the startup/run-time has to copy it from fixed ROM into uninitialized RAM, the zero memory is just described and cleared by the same code.
The RAM foot print is RW+ZI
gerardo
Posted on December 15, 2014 at 09:42
What is RTFM?
Posted on December 15, 2014 at 20:40
What is RTFM?
Read The Field Manual, Read The Fine Manual, ...
Beyond its early adoption by military personnel, electronic engineers and technicians, the principle of “helping oneself to knowledge� became more commonplace in other occupation fields, most notably in programming and customer support.
I'm sure the question is covered in the documentation, and has been asked/answered multiple times on the interwebs.
