Documentation Error in RM0390
KiptonM
Lead
Page 1078 CAN_TDTxR register bit field is missing a name in bit 8. Should be TGT.
5 REPLIES 5
KiptonM
Lead
I do not know how to tag this Documentation or Bug-Report.
You can add tags with the down arrow on the top right of the post. I added bug-report for you.
Imen.D
Hello @KiptonM​ ,
Thanks for your reported typo.
I raised this issue internally for fix in the coming release.
Imen
Imen
KiptonM
Lead
Thank you TDK. So a tag is called Add Topic. Are they case sensitive?
Kip
I'm not sure, but you can't create your own. Start typing and it will show auto-complete options that you can click on. That's how I do it at least.
