2020-09-09 1:24 PM
In RM0430 Rev 8, 9.3.19 DMA "Error management":
an interrupt is generated if the corresponding interrupt enable bit (TEIE, FEIE, DMIE) in the DMA_SxCR or DMA_SxFCR register is set.It should say "DMEIE", not "DMIE"
2020-09-10 12:53 AM
Hello @Miles ,
Thank you for your feedback
I will raise your reported case internally to take into consideration.
2020-09-10 12:53 AM
Hello @Miles ,
