Cannot copy bin data to Nucleo-F072RB.
Options
2020-09-09 11:31 PM
Hi
We have bought a Nucleo-F072RB board and tried to set up it following STSW-STUSB001 user manual.
Currently my process is till "Drag and drop of the configuration file (NUCLEO_F072RB_STUSB_NVM_config_1.6.bin) to STM32 Nucleo drive".
Situation is as follow;
- USB connection has succeeded and mounted drive on PC
- config file is unzipped and tried to drag and drop into Nucleo drive.
- After a couple of seconds the Evaluation board rebooted and drive shows initial file only. (.txt and .htm)
Could you advise any solution of this?
Thanks in advance.
Labels:
- Labels:
STM32F0 Series
Options
2020-09-10 12:52 AM
This is the expected behaviour. The ST-LINK debug chip on the board has flashed the target STM32F072RB MCU on the board with the .bin file. So you should be ready to continue with GUI setup.
