Difference between UM1974 & UM2179 - both ''Nucleo-144''
Posted on March 10, 2018 at 11:01
BothUM1974 & UM2179 have exactly the same title:
So how are we supposed to distinguish the two - without having to open both ?
Note: this post was migrated and contained many threaded conversations, some content may be missing.
12 REPLIES 12
Posted on March 11, 2018 at 13:33
Would you like to add the whole list of part numbers to the document name?
Posted on March 12, 2018 at 14:45
IMO it's not the naming of documents flawed, but the naming of boards.
They are different (or populated differently) thus they should have distinct names - and then the names of the documents would follow that.
PS more mess
https://community.st.com/0D50X00009XkaCWSAZ
Posted on March 12, 2018 at 17:47
Yes - presumably there is some key difference between the 'Nucleo 144' boards covered in one, and the
'Nucleo 144' boards covered in the other - so that should be reflected in both the board names and the corresponding document titles.
Rather like there is  the 'Nucleo 64' seriews, and the 'Nucleo 64-P' series - each with its own appropriately-titled User Manual.
(Although ISTR I couldn't find any clear definition of the difference between the 64 and 64-P,  without having to trawl through the 2 User Manuals - but that's another story.)
