Detecting ignition on/off through GPIO in a 12V automotive scenario. What is the preferred way to drive the input, protecting it from getting fried by electrical disturbances at a budget?
MikeMike
Will a voltage divider and a Zener diode pretty much suffice or will galvanic separation be necessary? Does anyone know/have an out-of-the-box solution?
Thanks,
Mike
3 REPLIES 3
gbm
Principal
Single 220 kOhm series resistor should be enough.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
Javier1
Principal
https://www.sunrom.com/p/tvs-diode-12v-bidirectional-smbj12ca-smb
check out TVS (Transient voltage supressor) diodes .
in automotive scenarios i always protect against 120V spikes from the battery (they do happen specially at motor startup/stall)
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
*automotive scenario*
