Details of Power down sequence of STM32N657X0H3Q
‎2025-03-14 5:26 AM
‎2025-03-14 5:45 AM
Hello @Tejas_P_R
For the power-up conditions, proceed in this order: 1, 2 and 3.
- Apply VDD and VDD18AON (VBAT connected to VDD if no external battery is used), this will give the output PWR_ON=1.
- Apply VDDCore (in external SMPS bypass using PWR_ON) and VDDSMPS in internal SMPS.
- Then apply the other supply: VDDA18PLL, VDDIOx, VDDA18PMU, VDDA33USB, VDDA18USB, VDD33USBCC, VDDCSI, VDDA18ADC, VREF+
For the Power-down, follow the procedure in reverse order 3, 2 and 1.
Best regards,
Romain,
‎2025-03-14 5:49 AM
Hi Romain,
Thanks for your reply...!
We will follow the power-up sequence as mentioned in datasheet, But If we are not going to use the power down sequencing and turning OFF all power supply at once will affect any functionality?
Tejas
‎2025-03-14 5:57 AM
In this case, you do not proceed with a power-down sequence, but with a complete direct shutdown.
This will not cause any problem.
Best regards,
Romain,
