2025-03-14 5:26 AM
2025-03-14 5:45 AM
Hello @Tejas_P_R
For the power-up conditions, proceed in this order: 1, 2 and 3.
For the Power-down, follow the procedure in reverse order 3, 2 and 1.
Best regards,
Romain,
2025-03-14 5:49 AM
Hi Romain,
Thanks for your reply...!
We will follow the power-up sequence as mentioned in datasheet, But If we are not going to use the power down sequencing and turning OFF all power supply at once will affect any functionality?
Tejas
2025-03-14 5:57 AM
In this case, you do not proceed with a power-down sequence, but with a complete direct shutdown.
This will not cause any problem.
Best regards,
Romain,
