Delay function using Tim
dmatheis
Posted on June 23, 2009 at 10:43
dmatheis
Posted on May 17, 2011 at 13:15
I'm a Newbie using Cortex-M3 and want to define a delay function using a tim. Do you have a simple example for this issue? I'm stuck here, because I don't know how to signal my delay function, that the timer count up or down is completed. I think setting a variable in the TIMx_IRQHandler() and waiting for this setting in my delay function is not an ideal solution (do you have a better one/example code?)?
thans a lot! :D
domen2
W/o any scheduling infrastructure there's not much else to do.
You could code your delay like this, so it uses less power:
void delay()
while (!timer_expired) {
asm volatile (''wfi''); /* or __WFI(); or whatever equivalent */
