Debug and driver folders are not created in code generation
‎2020-11-13 6:31 AM
Dear Sir,
Debug option is also not highlighted in menu button.
Below is the screenshot of that
please help.
‎2020-11-19 5:41 AM
Hello @Byede.1​ ,
Please provide a log file that will help our CubeMX team to analyse the issue.
Imen
Imen
‎2020-11-19 7:04 PM
Thanks for the reply.
Here i attached a document with clear screenshots of every step. Kindly go through it.
My problem is automatic code is not generated in STM32Cube IDE for any controller.
Please instruct me to resolve the issue.
*Thanks & RegardsY. Bala Nagendra *
‎2020-11-19 9:49 PM
- Dear Mam,
- Thanks for the reply.
- Here i attached a document with clear screenshots of every step. Kindly go through it.
- My problem is automatic code is not generated in STM32Cube IDE for any controller.
- Please instruct me to resolve the issue.
- *Thanks & Regards
- Y. Bala Nagendra *
- Like
- Reply
- Select as Best
‎2020-11-20 12:43 AM
Hi @Byede.1​ ,
Can you please share the ioc file, as well the log file that can be found in your user directory under the .stm32cubemx folder.
Imen
Imen
‎2020-11-20 3:23 AM
‎2020-11-20 3:24 AM
‎2020-11-23 6:08 AM
Hello @Byede.1​
Tested the same scenario without getting issue.
I would like to know if you use a proxy or not because; if you don't use a proxy, with Direct and Native, you don't have to fill in the fields (you have to leave them all empty), on the other hand if you use a proxy, you have to fill in HTTP and HTTPS.
Best regards,
Nesrine
‎2020-11-23 6:31 AM
Where i can find proxy settings in STM32 CubeIDE.
‎2020-11-23 6:38 AM
Hello @Byede.1​
Go to window ==> preference
Best regards,
Nesrine
