custom board support interface Creation
‎2016-12-12 11:39 PM
Hi. Can't find at uVision5 how to create custom board support interface for 'New Project'...... Thanks in advance
‎2016-12-13 3:44 AM
Hi
Grodetsky.Yury
,If you will use
uVision5
, there is no need tocreate a custom board support interface, you can simply:
Select the device that you will work with.
-> 'Manage Run-Time Environment' window will appear.
In section 'Board support', you will get a list of the available boards using the
chosen
MCU.Selectthe convenient board.
If this answers your request, please press 'correct'
.Regards,
Lawliet.
‎2016-12-13 5:33 AM
thanks, but i imply inclusion of support for my own hardware.......
‎2016-12-14 5:12 AM
Hi
Grodetsky.Yury
I advise you to use SW4STM32 IDE. It gives you the ability to create your own custom board.
Lawliet.
