CubeMX 4.16.0 download checksum is bad.
Andrei Chichak
Lead II
Posted on July 15, 2016 at 07:04
Downloading the 4.16.0 update yields the error message in the attachment.
The file checksum is wrong. I tried downloading about 6 times. Same result each time.
You can also correct the wording in the error message. Let me know if you need help.
slimen
Posted on July 15, 2016 at 11:34
I think 4.16.0 version is not yet available !
It will be interesting let me how you can download the 4.16.0 version? from web ? or CubeMx tool ?
Posted on July 15, 2016 at 14:00
From the screen shot it is reasonably apparent that it is CubeMX downloading. It can pull a manifest of currently available files and contains MD5 sum for them to provide end-to-end integrity by validating the files before unzipping them.
If the sum is the same but wrong each time it indicates the files on the server are wrong or out  of sync, rather than an issue transiting the internets.
stm32cube-t
Posted on July 19, 2016 at 10:28
Dear user,
We'll fix the issue asap.
To solve the issue within your installation, you can copy the file attached to your user directory in the folder: .stm32cubemx\plugins\updater\
Best regards
________________
Attachments :
updaters.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htj7&d=%2Fa%2F0X0000000aWE%2F0RRWRLpbpUaI_FoEeF25YuG0Mn8ueWQ4QKuOeO2_f2o&asPdf=false
