cubeMX 4.14 does not work with IAR
tarzan2
Posted on April 12, 2016 at 17:18
Hello
Compiling a test project for IAR:
Could not open file: 'E:\temp\cube4.14\test\EWARM\E:\Prog\STM32CubeMX_repo\STM32Cube_FW_F4_V1.11.0\Drivers\CMSIS\Device\ST\STM32F4xx\Source\Templates\iar\startup_stm32f439xx.s'
useless strcat...
Resulting in a 1/2 lost day... I hope that this new version of cubeMX will solve my problem, this morning I was searching why the I2C module sometime brings SDA low. The afternoon I can't compile anymore...
9 REPLIES 9
slimen
Posted on April 13, 2016 at 10:03
Hi bonelli,
I think your path is not properly set up: 'E:\temp\....\E:\Prog' !
I have checked from my side and successfully open the file startup_stm32f439xx.s
To have more idea about I2C module and SDA, you can refer to the
http://www2.st.com/content/ccc/resource/technical/document/reference_manual/3d/6d/5a/66/b4/99/40/d4/DM00031020.pdf/files/DM00031020.pdf/jcr:content/translations/en.DM00031020.pdf
-ForumSTM32-
tarzan2
slimen
Posted on April 13, 2016 at 12:44
Hi bonelli,
Please share your .ioc file to have more details about your problem.
-ForumSTM32-
tarzan2
slimen
Posted on April 13, 2016 at 23:16
I have also the wrong path when I copy the .ioc in other repository and re-generate it (concatenate previous/original .ioc location with new one) !
Maybe you can try to generate your project in new and clean repository (without copy .ioc or generating in old path)
tarzan2
Posted on April 14, 2016 at 10:53
This is what I do with the previous test folder.
I retried 2 times (STM32F4 & STM32L4), always in a clean folder, the problem is the same.
tarzan2
Posted on April 14, 2016 at 14:20
Please note that I tryed with an other computer, fresh installation of cubeMX => same results, paths are corrupted.
COULD ST PROVIDES OLDER VERSIONS OF CUBEMX ?
Because this one is NOT working with professional tools such IAR. So ALL my projects are waiting and as a professional this is NOT acceptable.
stm32cube-t
Senior III
Posted on April 15, 2016 at 10:07
Dear user,
This problem is under investigation. As a workaround, perform a ''Save Project as'' then generation is ok.
Best regards
stm32cube-t
Senior III
Posted on October 06, 2016 at 17:31
Dear user,
This issue has been solve in STM32CubeMX 4.16.
Best regards
