Cube Clock Confgration bug
f239955_stm1
Posted on May 19, 2016 at 09:00
Dear all ST staffs,
I found a bug about clock configuration for F429-NUCLEO in cubeMX. I want you to fix this problem.
To reproduce the bug, please make a new F429-NUCLEO project, and choose HSI as clock source. The frequency value of HSI at CubeMX is 8 MHz, but datasheet says it is 16 MHz.
I hope my contribution will help you.
Best regards, Fumihiko.
Walid FTITI_O
Senior II
Posted on May 19, 2016 at 13:10
Hi nimura.fumihiko,
Thanks dor the feedback and contribution. I will report this to our CubeMx team for check.
-Hannibal-
stm32cube-t
Senior III
Posted on May 24, 2016 at 10:48
Dear user,
Thank you for reporting this issue.
It will be fixed in a next release.
As a workaround you can manually change the HSI frequency value in the .ioc file:
RCC.HSI_VALUE=16000000
Best regards
