Creating .hex file from two banks memory of STM32H753
FBern.2
I have a problem with my .HEX file generated with KEIL 5.
In STM32H753 there are two banks memory:
FIRST BANK MEMORY : 0x08000000-0x080FFFFF
SECOND BANK MEMORY : 0x08100000-0x081FFFFF
My project has this structure:
0x08000000-0x08060000=> My own Boot
0x08060000-0x081FFFFF => My own app
When I obtain .bin file of my project (it was been converted from .hex file) the file is always 1 Mb and it contains the code of FIRST BANK MEMORY.
How can I obtain both .hex file? from first and second bank memory?
thank you.
best regards.
Fabio
22 REPLIES 22
Guru
If you application fits within the first bank, it's not going to generate any code beyond that.
Unfortunatly, My app doesnt fit in First bank​. It's large 0xc0000
I see no reason why the linker would only generate half of your project. See if the ELF contains everything and if so convert to hex with command line to help debug.
