Counterfeit IC?
rezaxyz
Posted on April 08, 2015 at 13:07
Hi all,
I�m designing a STM32F107VCT based embedded system. Unfortunately I�ve several problems with this part. For example the part wasn�t program correctly (Verification failed), and when I removed and soldered another chip, the problem solved. Since the Mouser and Digikey prices are about 2 times more expensive than I�ve bought, In your opinion is it possible my chips are fake or Counterfeit parts?
Thanks in advanced,
Reza
#programming-verfication-fail
4 REPLIES 4
AvaTar
Lead
Posted on April 08, 2015 at 13:27
In theory, yes.
For example the part wasn’t program correctly (Verification failed), and when I removed and soldered another chip, the problem solved.
I'd rather suspect inproper soldering, program/debug connection issues, or power supply issues. Perhaps in this order. Missing buffer caps, unstable supply voltage and too long SWD/JTAG wires could cause similiar problems.
rezaxyz
Posted on April 08, 2015 at 18:54
Thanks argentum.
Amel NASRI
Posted on April 10, 2015 at 10:45
Hello Reza,
Generally, the probability of counterfeited products cannot be totally discarded unless you are getting your parts from a trusted supplier.
So, we encourage you/your company to purchase ST products using authorized supply chains to substantially reduce the possibility of obtaining non-genuine ST products.
There is a list of authorized sales representatives and distributors on ST website: http://www.st.com/stonline/contactus/contacts/index.php.
You may contact your local distributor then if you are facing repeated issue with the received parts.
Thanks again for choosing ST products.
Best Regards,
-Mayla-
rezaxyz
Posted on April 20, 2015 at 13:11
Thank you Mayla.
