Cortex-M3 USART woes (still)
alexsardo9
Posted on April 03, 2010 at 03:10
11 REPLIES 11
alexsardo9
Posted on May 17, 2011 at 13:45
For what is worth, in the end the problem was with a (apparently) stripped down version of stm10x*_uart.h... Apparently my predecessor must have gotten and modified this. I replaced it with the one from the ST USART example and all worked fine.
The amazing thing is that I had no compile errors ever -- all seemed to work fine... Oh well, it's a learning curve I guess..
Thanks again guys.
''The amazing (sic) thing is that I had no compile errors ever''
No, that it not surprising at all!
Having no compiler errors simply tells you that you have not broken any 'C' syntax rules - it tells you nothing about whether your program will operate correctly or not!
