Connecting the JTAG reset signal
roman1
Posted on August 26, 2013 at 15:47
Hi there
I'm still a bit confused about whether I have to connect the nRESET pin of the 10-pin Cortex Debug Connector to the NRST or the NJTRST pin of the STM32 in case of both JTAG and SWD connection. Could anyone tell?
Roman
#jtag
3 REPLIES 3
Posted on August 26, 2013 at 16:13
NRST/NRESET is the PROCESSOR RESET, this is what you want.
NJTRST is not on this connector. If you need a full JTAG interface, say for boundary scan, you might want to check if you want all the signals on a different connector.
jpeacock2399
Posted on August 26, 2013 at 21:55
Segger (the J-Link vendor) recommends using JNTRST (the JTAG reset) on pin 10, with an option to connect NRST (procesor reset)  to pin 9.  I use this on an STM32F405 motor controller and it is working with GDB/Segger J-Link/Segger 10 pin adapter combination.
  Jack Peacock
Posted on August 26, 2013 at 22:39
The use of NRST is however far more common, and viable with J-Link and U-Link. I've reviewed half a dozen schematics and can't see anyone using NJTRST, either on the boards, or converter boards.
