2016-10-19 12:08 AM
2016-10-20 04:25 AM
FMC_SDRAM_CAS_LATENCY_3 | // ((uint16_t)0x0030)
You probably meant SDRAM_MODEREG_CAS_LATENCY_3 ? JW
2016-10-20 04:42 AM
Thank you JW,
once again i learn the lesson, that rhe problem sometimes is too simple to solve. PROBLEM SOLVED
