2022-11-23 04:47 AM
Is it possible to configure 1 or more timers to divide incomming pulses on a pin by a factor (for example 8) and send out the result on another pin?
Like this:
That way I would not need to implement the counter in software.
2022-11-23 05:02 AM
This should be possible with the timers, e.g. with the function Output Compare Toggle. Details can be found in AN4013 or in the respective reference manual, section Output compare mode.
/Peter
2022-11-23 05:02 AM
/Peter
