Can't access an[y] old thread
13 REPLIES 13
I've ran into this a few times in the past week. No clue why, but Google cache has the data:
https://webcache.googleusercontent.com/search?q=cache:M7acaS0BCJkJ:https://community.st.com/s/question/0D50X00009XkhdpSAB/lowpower-management-reset+&cd=1&hl=en&ct=clnk&gl=us
Links I have to older threads don't work either, so I believe the whole shebang simply crashed and the archive is in havoc.
It's also telling how the google cache is unusable courtesy of the idiotic cookie overlay (yes I know how to bypass it thank you very much, but that's not the point).
All threads older than 3 years do this. Literally - the boundary is somewhere between June and July 2018.
Given the attitude of folks who are responsible for this mess, I wouldn't be surprised if this is deliberate.
TSant.2
How to open the thread entitled "STM32F4 ADC1 starting conversion from TIM1 CC4 event - doesn't work":
https://community.st.com/s/question/0D50X00009XkZFdSAN/detail
How to bypass this cache issue more specifically?
Camilo LEMOS
Senior II
Thank you all for reporting this!
I've escalated the issue to the community IT team. I will let you know as soon as I have updates.
Apologies for the trouble.
Thanks, Camilo.
So, were you able to reproduce it?
Jan
@Community member​  Yes, I was able to reproduce it using a customer account, similar to yours. The issue doesn't happen using a moderator account, which helps us narrow down the issue a bit.
SLind.1
Same problem for me
