Bugs in STM32_USB-Host-Device_Lib_V2.1.0
pa
Posted on December 03, 2012 at 16:53
Hi all
I've tried to create a vcp communication with my STM32F4-Discovery, but I've some problems...
[code]
Description    Resource    Path    Location    Type
'struct <anonymous>' has no member named 'ddrsel'    usb_core.c    /USB_CDC_VCP/src    line 362    C/C++ Problem
'struct <anonymous>' has no member named 'i2cifen'    usb_core.c    /USB_CDC_VCP/src    line 394    C/C++ Problem
'struct <anonymous>' has no member named 'otgutmifssel'    usb_core.c    /USB_CDC_VCP/src    line 414    C/C++ Problem
'struct <anonymous>' has no member named 'phyif'    usb_core.c    /USB_CDC_VCP/src    line 361    C/C++ Problem
'struct <anonymous>' has no member named 'ulpi_utmi_sel'    usb_core.c    /USB_CDC_VCP/src    line 359    C/C++ Problem
'USB_OTG_GREGS' has no member named 'GI2CCTL'    usb_core.c    /USB_CDC_VCP/src    line 422    C/C++ Problem
'USB_OTG_GREGS' has no member named 'GI2CCTL'    usb_core.c    /USB_CDC_VCP/src    line 427    C/C++ Problem
'USB_OTG_GREGS' has no member named 'GI2CCTL'    usb_core.c    /USB_CDC_VCP/src    line 432    C/C++ Problem
'USB_OTG_I2C_PHY' undeclared (first use in this function)    usb_core.c    /USB_CDC_VCP/src    line 392    C/C++ Problem
request for member 'b' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 423    C/C++ Problem
request for member 'b' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 424    C/C++ Problem
request for member 'b' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 425    C/C++ Problem
request for member 'b' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 426    C/C++ Problem
request for member 'b' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 431    C/C++ Problem
request for member 'd32' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 422    C/C++ Problem
request for member 'd32' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 427    C/C++ Problem
request for member 'd32' in something not a structure or union    usb_core.c    /USB_CDC_VCP/src    line 432    C/C++ Problem
unknown type name 'USB_OTG_GI2CCTL_TypeDef'    usb_core.c    /USB_CDC_VCP/src    line 326    C/C++ Problem
unknown type name 'USB_OTG_CORE_DEVICE'   usb_otg.h
 /USB_CDC_VCP/src    line 50      C/C++ Problem
 /USB_CDC_VCP/src    line 51      C/C++ Problem
[/code]
Is there a newer version for the stm32f4 ore what?
Best regards
Patrick
Posted on December 03, 2012 at 18:32
There doesn't appear to be, but the compiler is choking on code you introduced
