[Bug] STM32CubeMX, SAI->xSLOTR, SLOTEN not shifted
Options
‎2016-01-20 4:50 AM
Posted on January 20, 2016 at 13:50
After spending an entire morning figuring out why my SAI configuration isn't working anymore I guess I found a new bug concerning the configuration of the SLOTR register inside HAL_SAI_Init.
Prior to 1.2.0hsai->Instance->SLOTR|= hsai->SlotInit.FirstBitOffset | hsai->SlotInit.SlotSize
| (hsai->SlotInit.SlotActive <<
16
) | ((hsai->SlotInit.SlotNumber - 1) << 8);
1.2.0
| hsai->SlotInit.SlotActive | ((hsai->SlotInit.SlotNumber - 1) << 8);
The missing shift at the SlotActive parameter causes the SLOTEN value to be set to a wrong value. Maybe the shift was left out intentinally but the CubeMX tool still produces the same output for the old and the current library version.
/edit
This was like the 5th bug I reported within 6 months. You guys should put up some kind of reward system for reporting stuff and send me a coffee cup or something. :D
4 REPLIES 4
Options
‎2016-01-20 6:06 AM
Posted on January 20, 2016 at 15:06
Hi Vinci,
Could you precise in which HAL library you have found the issue. So, we can verify it.-Syrine-Options
‎2016-01-20 8:09 AM
Posted on January 20, 2016 at 17:09
Ah damn it, I knew I'd forgotten something :p
It's concerning the L4-library.Options
‎2016-01-20 9:00 AM
Posted on January 20, 2016 at 18:00
Hi Vinci,
It is a known bug, and it is already fixed in the STM32CubeL4 version 1.2.0-Syrine-Options
‎2016-01-21 3:48 AM
Posted on January 21, 2016 at 12:48
You're right I'm sorry!
My bad, I got mixed up between two commits where the library got updated!
