2019-08-13 12:41 AM
I am trying to run a boundary scan test on a custom board with a STM32L4R5ZIT6,
My boundary scan tool of choice has highlighted some inconsistencies with the pins. When I set certain pins the wrong pins get set.
I checked the resources section on your website and I notice that the version of the
TM32L4R5/4S5/4R7/4S7/4R9/4S9 BSDL File is set as 2.0 with a date of Jul 06, 2018 but when I click on the link and open it the readme is still v1.0 and all the file headers are dated V1.0 29th August 2017. Is there an updated version available?
2019-08-16 06:43 AM
The BSDL Files are updated and fixed on ST website.
Best Regards,
Imen.
2019-08-15 02:05 AM
Hello @Rclar.13 ,
You’re right, the BSDL files on ST website need to be updated.
I raised this internally for fix and publish the new version instead the old content.
We will keep you informed about the update.
Thanks for bringing this issue to our attention.
Best Regards,
Imen
2019-08-16 06:43 AM
Best Regards,
Imen.
