Better way for mutlichannel ADC
TAndr.1
Hello. I have stm32f407 MCU. I need read 6 ADC channels by timer (2 Khz) and store adc data to 6 circular buffers. What is better way do this?
4 REPLIES 4
If you need 6 individual circular buffers, you'll need to postprocess the data to split them up. Results will be returned in a single buffer for each ADC, not for each channel.
TAndr.1
Is it possible split by hardware (dma)?
Nope.
No DMA will fill array in 6 word bursts. You'll need your processing task to step over as required (ie ptr += 6 rather than ptr++), or you'll need to deinterleave into arrays as you want them.
