2014-07-16 6:31 AM
Hello everybody
I'm trying to use the stack usb hid to talk with a barcode scanner. When I connect the scanner it is classified as a keyboard, but does not generate the interrupt events. Does anybody know why?thanks #barcode-scanner2014-10-11 12:06 AM
I use the
, it can work well in my program, and it may meet your need.2014-10-19 11:47 PM
Just google a
barcode reading solution
for your case. Hope it works for you. More to read:http://stackoverflow.com/questions/12497105/reading-usb-hid-barcode-scanner-input-without-knowing-vidpid Tags: ,2015-03-02 6:11 AM
Do you mind to share your code to me? Could you please send it to my email kqian@atcinc.net.
