2015-05-26 08:01 AM
I made a mistake of not putting BOOT0 pin connect to ground, which the STM32L051 MCU is not working at the moment. Is it possible to rewrite the bootloader to I could avoid checking the BOOT0 pin for development purpose only? The deadline would be too close for me to make another set of board.
If rewriting the bootloader is a method to go, any pointer to where to find the info?Thanks.2015-05-26 10:10 AM
No.
Lift the pin, use a jumper wire, or drill out the pin, etc. Whatever remediation techniques you have to address the connectivity issue.2015-06-02 08:00 PM
