Audible DAC/DualModeDMA_SineWave?
antonius
Posted on January 29, 2014 at 08:27
Guys,
I've tried :
DAC/DualModeDMA_SineWave/main.c
* @author  MCD Application Team
From Standard peripheral library, I can see it already on the osciloscope,
how can I make it audible ? How can I adjust the frequency ?
thanks
10 REPLIES 10
trevor23
Posted on January 30, 2014 at 12:38
No need for work around, a LM386 will work if used correctly. Did you add a low pass filter? Show the circuit diagram (else we are all just guessing what you've done wrong).
