Accessing SD Mass Storage Memory on STM3210B-EVAL
james239955_stm1_st
Posted on March 18, 2008 at 07:04
22 REPLIES 22
frank5
Posted on May 17, 2011 at 12:22
Can you please post this routine
how to call the disk_timerproc in the systick interrupt (each 10ms)?
Sorry, I am new in the STM32 family.
Thanks,
Frank
joneuhaus
I am new too.
I suggest you to run and understand the examples available on the website. It helps a lot to understand how it works.
The file stm32f10x_it.c contains all the interruptions.
You need to add the disk_timeproc function in SysTickHandler() that occurs each 10ms (if it is configured so >> see the configuration function above).
frank5
OK, I will read and check.
Frank
