Access Null pointer - M4 vs M33
‎2022-10-06 6:57 AM
Code that was compiled for stm32F407 ( core M4) has an bug that accesses null pointer. The assembly code is as follows:
STRB r1, [r0, #0x01]
Where r0=0 and r1=0.
Although MCU accesses null pointer, it does not enter hard-fault.
But, the same code on stm32U585 (core M33, w/o trust zone), runs into hard-fault.
Is there a way to make the stm32U585 to behave as the stm32F407, in this aspect.
This code cannot get changed and it must run on both MCUs.
Any Ideas?
Thank you,
Ari
- Labels:
DEBUG
STM32F4 Series
STM32U5 series
‎2022-10-06 7:02 AM
There's the FPB and you can also return from Hard Faults..
‎2022-10-06 7:58 AM
Thanks for reply.
Could you give me a link how to implement a safe return from hardfault for M33 core?
‎2022-10-06 2:19 PM
The LR call-gate indicates which stack frame the context is pushed on too. Check the faulting opcode, and advance the PC
‎2022-10-07 10:54 AM
But this means change in the code
‎2022-10-07 1:04 PM
Ok, pretty sure F4 and U5 have entirely different memory maps. I'm throwing paint in the air, hoping some of it will stick somewhere.
My guess would be there is *some* flexibility, and the issue here is some library, object or blob, where source is unavailable, then again it's not like that stuff can't get patched.
Let's say I can move the VTOR, and manipulate a vector, or two..
