A usable and minimal USB osciloscope with bluepill
epsi1on
hi guys,
I'm a desktop programmer and do not know much about micro controllers and electronics but i am very interested in making an oscilloscope  which:
- simple to build with well known parts and ICs
- it uses bluepill as the ADC and no other ADCs
- it be able to measure negative voltages
- It uses near maximum  ADC sample rate possible from bluepill
 Single channel would be enough for above spects. recently I was working with a cool project named rp2daq which convert RPI Pico to a 500KSps /12Bit resolution and uses USB to send data to PC.
I did try to make a proof of concept version of a oscilloscope on top of it and it did worked (kind of) available from here.
I was using this simple oscilloscope since last day which i gave 10v signal to it's ADC by mistake and it broke.
The pico is expensive relate to blue pill (in my area, 3x more expensive), so i am thinking if anyone interest in making such open source scope, i think I can fully do the desktop part and need help for the micro controller side.
Or at least you could give me some guidelines for that.
10 REPLIES 10
mƎALLEm
ST resources are only dedicated to supporting genuine ST products. We are not committed to ensuring that clones/fakes products work properly with the firmware we provide.
We suggest to purchase a genuine products and purchase them from known and trusted distributors.
Thank you for your understanding.
