7 segment display and hc595
‎2019-02-27 8:36 AM
Do not use scanning method.
Display with hc595 output.
display doing blink
The display does not remain steady when operating.
I suspect Spi.
I need help
thanks
#include "stm32f4xx_conf.h"
#include "stm32f4xx.h"
#include <stdio.h>
#define CLK GPIO_Pin_5
#define DATA GPIO_Pin_6
#define ENABLE GPIO_Pin_7
void spi_init(void);
void segment7(long counts);
unsigned char segment[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xE6};
void spi_init(void){
RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOG,ENABLE);
GPIO_InitStructure.GPIO_Pin = CLK | DATA|ENABLE;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_SetBits( GPIOC, CLK | DATA|ENABLE);
//hc595
void segment7(long counts) {
//////////DIJIT_1///////////////////////////////////////
for (i=0 ; i<8 ; i++){
GPIO_WriteBit(GPIOC, ENABLE, Bit_RESET);
GPIO_WriteBit(GPIOC, CLK, Bit_RESET);
GPIO_WriteBit(GPIOC,(segment[(counts/1)%10]>>i),&0x01);
delay_ms(20);
GPIO_WriteBit(GPIOC, CLK, Bit_SET);
delay_ms(20);
delay_ms(20);
GPIO_WriteBit(GPIOC, ENABLE, Bit_SET);
delay_ms(20);
//////////DIJIT_2///////////////////////////////////////
GPIO_WriteBit(GPIOC,(segment[(counts/10)%10]>>i),&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
//////////DIJIT_3///////////////////////////////////////
GPIO_WriteBit(GPIOC,(segment[(counts/100)%10]>>i),&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
//////////DIJIT_4///////////////////////////////////////
GPIO_WriteBit(GPIOC,(segment[(counts/1000)%10]>>i),&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
//////////DIJIT_5///////////////////////////////////////
GPIO_WriteBit(GPIOC,(segment[(counts/10000)%10]>>i),&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
//////////DIJIT_6///////////////////////////////////////
GPIO_WriteBit(GPIOC,(segment[(counts/100000)%10]>>i),&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
int main(void) {
int data= 123456;
SystemInit();
spi_init();
while(1) {
delay_ms(100);
segment7(data);
STM32F4 Series
‎2019-02-27 11:23 AM
Perhaps you can add some more white space or remove some subroutines?
My guess is it relates to configuring GPIOG clocks and pins, and then using GPIOC
‎2019-02-27 12:01 PM
#include <stdio.h>
#define CLK GPIO_Pin_5 // PC5 ?
void spi_init(void)
RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOC, ENABLE);
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC, CLK | DATA|ENABLE);
//hc595
void digit(long a)
unsigned char b = segment[a];
int i;
GPIO_WriteBit(GPIOC, DATA, ((b >>i) & 0x01) ? Bit_SET : Bit_RESET);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
digit((counts/1) % 10);
digit((counts/10) % 10);
digit((counts/100) % 10);
digit((counts/1000) % 10);
digit((counts/10000) % 10);
digit((counts/100000) % 10);
int main(void)
int data= 123456;
SystemInit();
spi_init();
while(1)
delay_ms(100);
segment7(data);
The DATA output looked busted too.
‎2019-02-28 3:20 AM
You don't include the circuit. My guess would be you are clocking from the buffer shift reg to the output shift reg every clock rather than every 8 clocks.
‎2019-02-28 4:41 AM
Thank you so much.
in main.
now work.
value showing full.
while (1) {
// winking here.
delay_ms (100);
segment7 (data);
I did something like that.
compiler gives warning but compiles.
src \ main.c | 1226 | warning: suggest parentheses around '-' inside '>>' [-Wparentheses] |
it works properly.
but (if) a lot.
void segment7(long counts){
int i=0;
for (i=0 ; i<48 ; i++){
if(i<8){
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i)&0x01);
else if(i>8&&i<16)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i-8)&0x01);
else if(i>16&&i<24)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i-16)&0x01);
else if(i>24&&i<32)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i-24)&0x01);
else if(i>32&&i<40)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i-32)&0x01);
else if(i>40&&i<48)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1)%10]>>i-40)&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
‎2019-02-28 4:50 AM
I sent this value incorrectly.
That's the employee.
int i=0;
if(i<8){
else if(i>8&&i<16)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/10)%10]>>i-8)&0x01);
else if(i>16&&i<24)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/100)%10]>>i-16)&0x01);
else if(i>24&&i<32)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/1000)%10]>>i-24)&0x01);
else if(i>32&&i<40)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/10000)%10]>>i-32)&0x01);
else if(i>40&&i<48)
GPIO_WriteBit(GPIOC, DATA,(segment[(counts/100000)%10]>>i-40)&0x01);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(20);
