X-CUBE MCSDK FOC Firmware related issue
‎2018-09-10 5:55 AM
I am having stm32f3 FOC firmware. I downloaded it from st website as X-cube MCSDK full version. But, even after inserting all my header and source files, the code is not working. anyone help me whether i have to make any change in given foc firmware to my microcontroller STM32f302R8. I want the complete procedure.
help me !
STM32 Motor Control
‎2018-09-11 12:33 AM
I can suggest you to check the video to help you to get started: https://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-mcsdk.html#
or to check the application note: https://www.st.com/resource/en/user_manual/dm00484271.pdf
Then if you need to modify the code , you can rely on the user manuals and the following AP notes: https://www.st.com/resource/en/application_note/dm00505156.pdf
The procedure is the same for the Full version.
If you have still problems, please don't hesitate to send us more details.
Best regards,
Claire
‎2018-09-19 12:43 AM
sorry claire, I generate codes using st workbench and after then modify using stm32cubemx, but still it shows some problem in arm_math.h header files problem in arm_fir_f32.c. Arm fuctions shows problems. can you please help me regarding this.
‎2019-02-27 6:29 PM
Hello.
The tool you downloaded was XCUBE-MCSDK or XCUBE-MCSDK-FULL. If FULL, please give me the tool at mail phuocnguyenhuu96@gmail.com. Thanks so much.
‎2021-06-27 10:27 PM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
