Will Switched Reluctance option be enabled in the ST MC Suite?
JAles.1
I noticed that Switched Reluctance motor control is an option in the MC Suite but it is not selectable. Are there plans to support switched reluctance control in the future? Who's working on SR implementation on ST hardware?
Laurent Ca...
Lead II
Dear  @JAles.1​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
Laurent Ca...
JAles.1
I'm confused - how would I have been able to solve this issue? Isn't it an internal ST issue?
Laurent Ca...
Lead II
The question has moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 SDK).
Best regards
Laurent Ca...
