Hello, I have been using the evaluation board STEVAL SPIN3202 and a bldc motor. the board connects to the motor control workbench but as soon as i push the button "start motor" the board disconnects .
MOUSM.1
and I have an error " communication is closed, the board does not work correctly" . what should I do to solve this problem? I have checked the power supply and I tried to reflash the board but always the same problem.
Thank you ,
Mohamed
Laurent Ca...
Lead II
The question has moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 SDK).
Best regards
Laurent Ca...
