Stepper Motor Unexpected Direction Change at High Speeds
Options
2025-01-29 2:54 AM
When I increase the speed of the stepper motor, it sometimes changes direction on its own before touching the limit switch. The limit switch is attached to the horizontal shaft and moves with it. When it remains stationary, the system works fine, but at higher speeds, the motor occasionally changes direction unexpectedly. What could be the cause of this, and how can I fix it?
Labels:
STM32 Motor Control
0 REPLIES 0
