2020-11-17 04:54 AM
Hi Everyone
While generating the code, I get the following error and finally I get a "complated with errors" warning.
It did not give such an error before. I faced such a problem the next day when I turned on my computer and created a new project.
I deleted Cubemx and MCSDK and reinstalled the problem didn't fix.
When I compile the code, it doesn't give an error.
The code actually works properly when I run my driver card in shunt resistance mode.
But I want to test with ICS current sensor and ICS does not run the motor properly in current sensor mode. I had used this sensor before and there was no problem.
I installed and tried programs on another PC and it came out with no problem.
I'm adding the log files of each.
Thank you for your support in advance.
Respectively
Shunt Mode - No Error
ICS Mode - No Error
ICS Mode - Complated with error
Shunt Mode - Complated with error
2020-11-19 12:00 AM
Dear @Mustafa Çakmak
Could you give more information about your setup?
More especially regarding the HW part.
Best regards
Laurent Ca...
