2021-09-07 12:17 AM
I am using NUCLEO-F303RE,
I have purchased a power board (IPM evaluation board EVALM13645ATOBO1) from Digikey.
Is automatically calculated? or Is the user needs to configure this value?
If yes, where or how to find/check these values? 3. is it possible to change the board details once it is selected.
2021-09-14 10:04 PM
Dear @Mathan Raja
We are sorry but we only support ST power boards.
I don't know your board but I guess you can design your own based on a similar existing board.
Best regards
2021-09-20 03:31 AM
Hi Laurent,
which ST power board is the same as EVALM13645ATOBO1 ( Equivalent)?
How can I use Motor Profiler software (for finding motor parameters), with the Nucleo-F303RE & EVALM13645ATOBO1 boards?
