2024-12-30 06:06 PM
We are operating the motor with the Run command “Run(DIR, SPD)” to rotate it at a constant speed. However, when the speed (SPD) is varied and then returned to the same SPD, we observe a significant increase in current.
Therefore, could continuously sending the Run command while the motor status is “constant speed” affect the phase current adjustment in some way?
