2022-09-30 09:36 PM
I want you to help explain and help fix it.
Motor 48 volts, 600 watts, number of pairs of poles 52/2=26
or the motor is too big, please reply, thank you very much.
2022-11-16 04:52 AM
I ran into that problem.Troubleshooting is very difficult.Doesn't work as intended
2022-11-16 05:06 AM
I tried to fault-find the circuit but it is almost impossible without any of the original design information. I ended up having to run my motor at 12V only during development then I will move to a custom board for the final product.
2022-11-16 06:22 AM
your work is interesting
Is there a project that will be used with a motor of any size? 48v 72v 84v
500w 1000w 2000w 3000w?
Can you share your experience?
