How to start PMSM in open Loop FOC and Transition to closed LOOP FOC using HALL Sensor
‎2021-02-22 7:12 AM
Hi Team,
Please provide API and steps to transition from an Open Loop FOC to a closed Loop FOC using HALL Sensor
I am using motor control SDK 5.4.0
Thanks,
Krupashankar
- Labels:
STM32 Motor Control
‎2021-03-08 5:47 AM
Dear @KE.1​
I forward your question to our expert.
Just in case, it is better to have the last SDK version (which is SDK5.4.5, and very soon SDK 5.4.6)
Best regards
Laurent Ca...
‎2021-04-05 8:28 PM
@Laurent Ca...​
May i know in your SDK 5.4.6 which support "open Loop FOC and Transition to closed LOOP FOC using HALL Sensor" method ?
thanks
‎2021-05-31 8:07 PM
The SDK itself doesn't support switching speed sensor online, but you can enable both the main feedback (sensorless) and the aux feedback (hall), and add a piece of code to switch the sensor properly.
‎2021-06-02 2:48 AM
I'm interested in that topic as well.
@Laurent Ca...​ Could you specify a little bit deeper how to switch between the both speed feedback modes? I couldn't find the right "spot" where this could be done.
Thank you very mutch!
