How to get a BLDC running with STEVAL-SPIN3204.
Curve Wrecker
I have gennerated "6Steps-STEVAL-SPIN3204" project with MC SDK and downloaded code to flash memory.But when I press SW2, nothing happened.
1 REPLY 1
YBhat.4
Hi @Curve Wrecker​
Check again with all the parameters like board and motor selection initially.
Also make sure you are using updated version of the software(MC Workbench, Cube MX, IDE).
Try resetting the board if no response(after flashing the code).
