How to configure FO�?¡-SDK for build-in NTC
Artem Zolotov
Posted on June 10, 2018 at 23:31
IPM module STGIPQ3H60T has build-in NTC. How to configure the temperature sensing with build-in NTC for the FO?-SDK?
Thank you,
Artem
#foc-sdk #temperature-sensing #build-in-ntc
cedric h1
Posted on June 11, 2018 at 12:49
Dear Artem,
Unfortunately, the FOC SDK does not support yet negative ramp. It will be added latter.
For the time being, you can use virtual temperature sensor (it will send always 25 deg) for debug purpose.
Cedric
If you agree with my answer, please accept it by clicking on 'Accept as solution'."
Laurent Ca...
Lead II
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
