2020-01-06 4:46 PM
Hello! I'm trying to smoothly brake a three phase brushless motor, by short circuiting the phases. At this moment an overvoltage occurs damaging the power circuit. Is this the right way to do it? Thanks
2020-09-13 7:43 AM
Instead of shorting the phases, I have a another option for you.
Use another one switch(external Switch) when switch is opened it will give high command to MCU. During that time your MCU will stop all PWM.
So this method is smooth than short circuiting the phases.
2020-09-10 11:55 PM
Dear marco siqueira
Do you have still this problem to solve?
Best regards
Laurent Ca...
2020-09-11 2:13 PM
Yes, could you help me?
2020-09-13 7:43 AM
2020-09-23 10:08 AM
Dear @marco siqueira
Does the solution proposed by @Karthik DM OK for you?
Best regards
Laurent Ca...
2020-10-30 3:23 AM
I guess it does, therefore I consider this thread closed.
If not, feel free to reopen it by posting an answer.
Best regards
Laurent Ca...
2021-02-15 2:47 AM
@marco siqueira
Is it possible to share how to smoothly brake a three phase brushless motor?
