2025-01-14 12:43 AM
I have a STSPIN32F0A board on which, I need support on below points
1) Ability to operate the motor through LIN/PWM signal rather than an ADC signal, currently the EVAL board supports an ADC through an onboard potentiometer which I want to remove.
2) My current design is not able to move beyond 1.5A rms, whereas the design can support up to 15A rms, How to rectify this issue?
