How I can Define motor parameters...
‎2020-09-25 2:24 AM
How I can Define motor parameters if I do not find my board (steval spin3201) in Motor Profiler? Where is AN and anything??
‎2020-09-27 11:39 PM
:) You can measure the parameters. here is a construction video by ST:
https://www.youtube.com/watch?v=XnGHpT96Ri4&list=PLnMKNibPkDnEgc7QwaabA5SKz5_4Mwz4e&index=2
‎2020-09-28 2:56 AM
Is there AN for that video?
‎2020-09-28 11:38 PM
If I have Delta, but not Y? Can I use your excel file from ST(https://drive.google.com/file/d/1h65CbRM2873G1HbrXkNwsbGvlFeTb8Dm/view)? https://www.youtube.com/watch?v=XnGHpT96Ri4&list=PLnMKNibPkDnEgc7QwaabA5SKz5_4Mwz4e&index=2
‎2020-10-09 5:36 AM
Hi @oleg_sidorovich_1981​,
yes you can use the excel also for delta connection.
In both cases, the measurements is always made between two motor phases and the excel file translates the measures into an equivalent model that is unrelated to the actual motor phase connection.
‎2021-06-27 9:25 PM
Adding of STM32 Motor Control topic.
Best regards
