2025-09-12 1:07 AM
“I have both an encoder and a Hall sensor. From what I understand, when using the encoder to measure speed, the motor moves at startup to align the encoder. However, I can’t accept this because in most applications unwanted movement is not acceptable. How can I solve this problem? Is it possible to use the Hall sensor to get the initial angle?”
