2023-03-29 04:20 AM
I did connected the board to PC with USB2.0 cable, and I suuplied 24V DC to the board(STEVAL-SPIN3204) and set the baudrate to 9600 bps, still this problem happens.
2023-03-29 04:30 AM
Hello Curve Wrecker,
May I ask which version of the MCSDK you are using, as well as the IDE you used to flash the Firmware on the board ?
Gaël A.
2023-03-29 04:52 AM
I'm using version 5.4.8, and I chose Keil MDK-ARM V5 as the target Toolchain. When I build the project,I also encountered error L6406E but I don't know how to deal with it.
2023-03-29 05:01 AM
The L6406E error refers to a lack of space in your target MCU. If you are using a free licence for Keil, maybe there are some limitations about the size of the program.
Have you tried generating the project on CubeIDE ?
https://www.st.com/en/development-tools/stm32cubeide.html
Gaël A.
2023-03-29 05:05 AM
Thanks, I'll try it.
