Can someone explain the equations for Space vector PWM implementation in section 4.11 in UM1052?
‎2020-09-11 3:22 AM
I am trying to understand Field Oriented Control and use it on an STM32 MCU and I have a question on the implementation.
I have read UM1052 and the presentation on fundamentals of motor control which explains some things nicely and I now want to understand how are the voltage phases (pwm center-aligned duty cycles) calculated from the orthogonal motor-aligned voltages Vα, Vβ.
I understand how the phases can be computed graphically by reading this but I don't understand the motive for the equations in 4.11 of UM1052.
What are Uα, Uβ for? Do they have some meaning?
What are X, Y and Z supposed to represent?
How did they come up with these equations?
Thank you very much.
Sat
STM32 Motor Control
TIM
‎2020-09-22 1:02 AM
Dear Dimitris Paraskevopoulos
We will try to answer to question ASAP.
In the meantime, if you can give me some information :
- are you searching a solution for a project or is it just a study for learning?
- and if you search a solution have you already some material (boards, motors and so on) and SW (tools, internal SW dev and so on)?
Best regards
Laurent C.
‎2020-10-01 7:29 AM
Dear @Dimitris Paraskevopoulos​
Do you have still this problem to solve?
Best regards
Laurent Ca...
‎2020-10-01 1:20 PM
Hi Laurent,
Yes I would like to know the answer to this please.
Cheers
